Home > Monitors and Touchscreens > 7" Touchscreens >
  Xenarc 700TSV 7" TFT LCD Touchscreen Monitor
  Xenarc 700TSV 7
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD screen with VGA input and Touchscreen.  In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector.
This popular product incorporates the innovation of our VGA 7" Models along with a 5-wire resistive Touch-Screen panel.  Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface.  You can connect several 700TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
These monitors come included with an instruction manual, a copper monitor stand, an AC adaptor,  a connection cable, cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Linux, and Mac OS.
Our Price: $359.95
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MON-004
Accessories:
Description Technical Specs Extended Information
This popular touchscreen product incorporates the innovation of our VGA 7" models along with a 5-wire resistive Touch-Screen panel. Use the convenient touch-screen as your input device, controlling your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 700TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
These monitors come included with an instruction manual, a monitor stand, an AC adaptor, a touch screen driver/software CD, a connection cable, and a cigarette lighter car adaptor.
The 700TSV comes in Black color only.
Now Shipping the new 2008 models. New models have the following changes:
- Improved Brightness (500cd/m²)*
- Improved Contrast (400:1)
- Improved Viewing Angle and Response Time
- 5-wire Resistive Touchscreen
- New Features (Mirror & Vertical Image Flip)
* - While the manufacturer assures us that the upgrade has been made from the 400cd/m2 units from 2007, the packaging does not reflect this.  Please be assured that the product you will receive is a 2008 model with 500 cd/m2.
Features
  • Model #: 700TS / 700TSV
  • Screen Size:  Diagonal 7"  (16:9)
  • Viewable Area: 156mm X 92.5mm (cut out dimensions for the actual display portion of the screen)
  • Physical Resolution: 800 (H)  x 480 (V) WVGA
  • Supported Resolution:  640 x 480 ~ 1600 x 1200
  • Dot Resolution: 2400 x 480 = 1,152,000 (dots)
  • LCD Brightness: 500 cd/m²
  • Contrast Ratio: 400:1
  • Viewing Angle: 140° Horizontal, 100° Vertical
  • Touch Screen Interface: USB port
  • Operating Voltage Range: DC 11V ~ 24V
  • Power Supply: DC 12V
  • Power Consumption:  <8W
  • Operating Temperature:  23°F ~ 158°F
  • Storage Temperature:  -22°F ~ 185°F
  • Dimension (in):  7.75W x 4.75H x 1.38D
  • Weight (lb):  1.28
  • FCC, CE, E13 Certification
  • ROHS Compliant
  • 18 Month Warranty
    *LCD Panel Manufacturer's test result based on specific test environment. Number corresponds to maximum output and should not be confused with typical output. Typical output has to compensate for different factors and is also reduced to prolong the life of CCFL.
5-Wire Resistive Touchscreen Advantages:
  • 5-wire resistive analog technology is superior to 4-wire, 8-wire and resistive matrix technologies
  • Most durable resistive analog - drift-free operation even when exposed to temperature fluctuation
  • Life span of 35,000,000 touches versus 1,000,000 touches from 4-wire resistive
  • Increased optical clarity equals higher brightness and a sharper display
  • Greater touch point density means better accuracy
  • Faster response time and increased speed
  • No external electronic correction needed
The Xenarc 700TSV casing dimensions as it comes in the box are:
Height: 125mm
Width: 195mm
Depth: 34mm
  • For In-Car Computing, PC, Server, GPS, and various VGA Use
  • High Brightness, High Contrast LCD Panel *New*
  • 5-wire resistive Touch Screen (USB) *New*
  • Multi-Monitor Touchscreen Support
  • VGA Input (15 pin D-SUB) x 1 (700TS) or VGA Input x 1 & Video Input x 2 (700TSV)
  • Length of VGA cable roughly 6 feet.
  • Audio Input / Built-in Speaker (700TSV)
  • NTSC / PAL Multi-System (700TSV)
  • 16x9 Aspect Ratio
  • High Resolution Display - up to 1600 x 1200
  • Auto detects 800x480 resolution
  • Upgraded High-Brightness CCFL Backlight
  • Adjustable backlight level for night-time use
  • Pixelworks High Performance Image and Video Signal Processor
  • AISS - Advanced Image-Scaling and Shaping
  • 16:9 / 4:3 Scaler settings
  • Last Input memory (700TSV)
  • Last Power setting memory
  • IR Remote Control (700TSV)
  • Auto power-on upon signal detection
  • Automatic display adjustment
  • On Screen Display Control
  • Mirror Image Flip (VGA and Video Modes) *New*
  • Vertical Image Flip (VGA and Video Modes) *New*
  • Copper Stand: 360° / Height Adjustment
  • 20-Pin heavy-duty connector
  • Anti Glare Coating
  • Supports 11V DC ~ 24V DC
  • "E" Mark Certified for Automotive use
Related Products...
New! 7'' Transflective LED Backlit Sunlight Readab
Our Price: $729.99
Add
New! Mp3Car 2008 7'' Transflective LED Backlit Sunlight Readable Monitor
Lilliput 629GL-70NP 7" VGA Touchscreen w/ Auto Ba
Our Price: $259.99
Add
Lilliput 7" VGA Touchscreen 619GL-70NP
Our Price: $224.99
Add
Lilliput 7
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor
Our Price: $269.99
Add
Xenarc 705TSV 7
Xenarc 702TSV VGA Touchscreen Monitor
Our Price: $484.99
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
MP3CAR USB GAMEPLATE WITH 110 VOLT A/C PLUG AND RCA'S! $32.99
Stage 2 - Above the Basics $367.99 Please allow up to 3 business days for processing.
Klear Screen High Performance Cleaning Kit $2.99
Xenarc 700IDT 7" In-Dash LCD Touch Screen Monitor $415.00
25ft VGA Extension Cable $20.00
CarNetix CNX-XSC3 Cable Kit for the Xenarc MP-SC3 Power $14.95
MacPac Power Cable Kit $29.99
7" Touchscreen Replacement for 619 & 629 Lilliput (old version) $50.00
