Please note: CA residents will be charged an additional 8.75% tax rate on this item after your order is finalized.
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD screen with VGA input. In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector.
Don't mistake this monitor for an ordinary video monitor that displays composite video. This 7" monitor has 800 x 480 pixels (2400 x 480 sub-pixels) that help display crystal clear texts and ultra-sharp images through your computer's VGA signal.
These monitors come included with an instruction manual, a monitor stand, an AC adaptor, a connection cable, and a cigarette lighter car adaptor .
A Touchscreen version of 700YV is also available, Model # 700TSV.
- Model #: 700Y / 700YV
- Screen Size: Diagonal 7" (16:9)
- Physical Resolution: 800 (H) x 480 (V) WVGA
- Supported Resolution: 640 x 480 ~ 1024 x 768
- Dot Resolution: 2400 x 480 = 1,152,000 (dots)
- LCD Brightness: 500 cd/m²
- Contrast Ratio: 400:1
- Viewing Angle: 140°
Horizontal, 100° Vertical
- Operating Voltage Range: DC 11V ~ 24V
- Power Supply: DC 12V
- Power Consumption: <8W
- Operating Temperature: 23°F ~ 158°F
- Storage Temperature: -22°F ~
185°F
- Dimension (in): 7.75W x 4.75H x 1.38D
- Weight (lb): 1.28
- FCC, CE, E13 Certification
- ROHS Compliant
- 18 Month Warranty
- For In-Car Computing, PC, Server, GPS, and various VGA Use
- High Brightness, High Contrast LCD Panel *New*
- VGA Input (15 pin D-SUB) x 1 (700Y) or VGA Input x 1 & Video Input x 2 (700YV)
- Audio Input / Built-in Speaker (700YV)
- NTSC / PAL Multi-System (700YV)
- 16x9 Aspect Ratio
- High Resolution Display
- Auto detects 800 x 480 resolution
- Upgraded High-Brightness CCFL Backlight
- Adjustable backlight level for night-time use
- Pixelworks High Performance
Image and Video Signal
Processor
- AISS - Advanced Image-Scaling and Shaping
- 16:9 / 4:3 Scaler settings
- Last Input memory (700YV)
- Last Power setting memory
- IR Remote Control (700YV)
- Auto power-on upon signal detection
- Automatic display adjustment
- On Screen Display Control
- Mirror Image Flip (VGA and Video Modes) *New*
- Vertical Image Flip (VGA and Video Modes) *New*
- Copper Stand: 360° / Height Adjustment
- 20-Pin heavy-duty connector
- Supports 11V DC ~ 24V DC
- "E" Mark Certified for Automotive use
