Home > Monitors and Touchscreens > 7" Touchscreens >
  Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs
This popular product incorporates a 4-wire resistive Touch-Screen panel. Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 705TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
This monitor comes included with an instruction manual, a copper monitor stand, a stylus, an AC adaptor, a connection cable, a cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Windows Vista, Linux, and Mac OS.
Our Price: $259.95
Stock Status:In Stock
Product Code: MON-053
Description Technical Specs Extended Information
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD Touchscreen monitor that utilizes a LED backlight system. The result is a monitor with less power consumption and a thinner profile.
Mp3Car Review - The 705TSV doesn't have some bonus features like AISS (
Advanced Image-Scaling and Shaping) and "Mirror Image Flip" like the 700TSV. However the monitor has an LED back-lit panel with higher brightness and higher contrast ratio than traditional CCFL back-lit monitors. The construction is ideal for mounting and custom molding due to the sharp corners and flat edges. The cord connections are recessed to hide them from abuse. This is a great lower priced quality touchscreen monitor.
Features
    • For In-Car Computing, PC, Server, GPS, and various VGA Use
    • High Brightness, High Contrast LCD Panel
    • 4-wire resistive Touch Screen (USB)
    • Multi-Monitor Touchscreen Support
    • VGA Input (15 pin D-SUB) x 1 & AV Input x 2
    • Audio Input / Built-in SpeakerNTSC / PAL Multi-System
    • 16x9 Aspect Ratio
    • High Resolution Display
    • Auto detects 800x480 resolution
    • High-Brightness LED Backlight
    • Adjustable backlight level for night-time use
    • High Performance Image and Video Signal Processor
    • Last Input memory
    • Last Power setting memory
    • IR Remote Control
    • Auto power-on upon signal detection
    • Automatic display adjustment
    • On Screen Display Control
    • Copper Stand: 360° / Height Adjustment
    • 26-Pin heavy-duty connector
    • Anti Glare Coating
    • Supports 11V DC ~ 24V DC
    • "E" Mark Certified for Automotive use
    • Compare Features
  • Specifications
    • Model #: 705TSV
    • Screen Size:  Diagonal 7"  (16:9)
    • Physical Resolution: 800 (H)  x 480 (V) WVGA
    • Supported Resolution:  640 x 480 ~ 1024 x 768
    • Dot Resolution: 2400 x 480 = 1,152,000 (dots)
    • LCD Brightness: 450 cd/m²
    • Contrast Ratio: 400:1
    • Viewing Angle: 140° Horizontal, 120° Vertical
    • Touch Screen Interface: USB port
    • Operating Voltage Range: DC 11V ~ 24V
    • Power Supply: DC 12V
    • Power Consumption:  <5W
    • Operating Temperature:  23°F ~ 158°F
    • Storage Temperature:  -22°F ~ 185°F
    • Dimension (in):  7.63W x 4.88H x 1.14D
    • Weight (lb):  1.15
    • FCC, CE, E13 Certification
    • ROHS Compliant
    • 18 Month Warranty
Browse for more products in the same category as this item:
Monitors and Touchscreens > Xenarc
Xenarc 702TSV VGA Touchscreen Monitor, 1000nit $459.95
Xenarc 700TSV 7" TFT LCD Touchscreen Monitor New 2010 Model $319.99
Xenarc 700IDT 7" In-Dash LCD Touch Screen Monitor $399.95
Xenarc 706TSA 7" TFT LCD Touchscreen Monitor w/ DVI & VGA & AV inputs $409.95
XENARC 700TSU 7" TFT LCD Touch Screen Monitor w/ USB Display Interface & AV inputs $349.00
