Home > Monitors and Touchscreens >
  Xenarc 706TSA 7" TFT LCD Touchscreen Monitor w/ DVI & VGA & AV inputs
Our Price: $409.95
Stock Status:In Stock
Product Code: MON-055
Description Technical Specs Extended Information
This monitor utilizes a separate input box which allows a very clean installation.  There is only one cable that needs to be connected to the monitor.  The external input box takes care of power, a DVI input, a VGA input, 2 Composite video inputs, and 3 audio inputs.  And with an optional cable, the monitor can sit 5 Meters away from the input box.  LVDS signaling is utilized between the monitor and the input box to minimize signal degradation.
Utilizing the newest Pixelworks advanced high performance video processor, the 706TSA provides outstanding signal processing, de-interlacing, and scaling.  This is the same chip that is used in high-end TVs and projectors.
Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface.  You can connect several 706TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
Features
    • For In-Car Computing, PC, Server, GPS, and various VGA Use
    • Automotive Grade 650NIT LCD Panel
    • Twin-tube High-Brightness CCFL Backlight
    • 5-wire resistive Touch Screen (USB)
    • Multi-Monitor Touchscreen Support
    • DVI-D Input x 1
    • VGA Input (15 pin D-SUB) x 1 & Video Input x 2
    • Audio Input x 3 / Built-in Speaker
    • Picture In Picture / Split Screen
    • NTSC / PAL Multi-System
    • 16x9 Aspect Ratio
    • High Resolution Display - up to 1600 x 1200
    • Auto detects 800x480 resolution
    • Automatic backlight level adjustment through built-in ambient light
    • sensor
    • Pixelworks High Performance
    • Image and Video Signal
    • Processor
    • AISS - Advanced Image-Scaling and Shaping
    • 16:9 / 4:3 Scaler settings (Auto, Fill All, 1 to
    • 1, Normal, Zoom, Wide)
    • Last Input memory
    • Last Power setting memory
    • IR Remote Control
    • Auto power-on upon signal detection
    • Automatic display adjustment
    • On Screen Display Control
    • Mirror Image Flip
    • Vertical Image Flip
    • Copper Stand: 360� / Height Adjustment
    • Brushed aluminum front bezel
    • VESA 75mm mounting holes
    • 20-Pin and 26-Pin heavy-duty connectors
    • Anti Glare Coating
    • Supports 10V DC ~ 24V DC
    • "E" Mark Certified for Automotive use
Browse for more products in the same category as this item:
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > Xenarc
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs $259.95
XENARC 700TSU 7" TFT LCD Touch Screen Monitor w/ USB Display Interface & AV inputs $349.00
NEW 2010 Model XENARC 1020TSV - 10.2" VGA LCD Touchscreen Monitor $458.95
VoomPC-2 CarPC Enclosure $89.95
Volume Control (Rotary Potentiometer) $9.99
