Home > Monitors and Touchscreens >
  Xenarc 7" IN-DASH Touchscreen VGA Monitor / DVD Receiver MDT-X7000
Our Price: $665.00 Discontinued, No Longer Available.
Stock Status:(Out of Stock)
Availability:: Usually Ships in 1 to 2 Business Days
Product Code: MON-049
Description Technical Specs Extended Information
Please note:  CA residents will be charged an additional 8.75% tax rate on this item after your order is finalized.
Xenarc Technologies Corp. introduces the new and improved 1-DIN touchscreen monitor / DVD receiver that was designed with In-Car Computing in mind.  This unit suits you well whether you are installing In-Car computer now or you just want to have a regular receiver that could be used with a computer in the future.
This advanced DIN touchscreen monitor / DVD receiver plays video DVDs and audio CDs like a regular head-unit.  You can control all the functions including DVD playback and changing your Radio channels through its touchscreen.  The built-in 55Wx4 amplifier provides ample sound to your car speakers.  And the fun begins when you switch the unit to PC mode.  Its touchscreen turns into a input device that works like a mouse where you can click, select, and drag.  Its slot-load DVD drive turns into a DVD-ROM that works just like an external USB DVD-ROM drive.  The built-in 2 port USB hub allows you to connect USB devices to your computer with ease.  The multi-function remote control allows you to control windows media playback functions.  And you get all these with only one simple USB connection to your computer.  There is even a front PC power button that allows you to control the power of your In-Car Computer.  With all these features, you can use this monitor as the front end control unit and hide away your In-Car Computer underneath the seat or inside your trunk.  And with the future in mind, the unit has a VGA (D-Sub15) input, as well as a DVI-D digital input.  Built with the finest materials, its automotive grade LCD panel looks brighter than  other LCD panels of the same rating.  And the unit's Piano black finish and high quality dark chrome electroplated knobs are examples of the details that we have gone into.  We know our customers expects the best, and so we provide them with the best.
Car computer sold separately HERE.
This monitor comes included with a remote control, an instruction manual, connection cables, and touchscreen drivers for DOS, Windows, Windows Vista, Linux, and MAC OS.
Features
    • For In-Car entertainment, In-Car Computing
    • TMD Automotive Grade LCD Panel
    • Fully motorized screen with Tilt adjustment
    • Built-in 55w x 4 amplifier
    • Built-in CD, video DVD player
    • Built in DVD decoder with Dolby Digital
    • USB DVD-ROM in PC mode
    • Built-in AM/FM Radio Tuner
    • 5-wire resistive Touch Screen (USB)
    • Multi-Monitor Touchscreen Support
    • DVI Input x 1 / VGA Input x 1,  AV Input x 2
    • PC Audio input x 1, AV Output x 1
    • Built-in 2 port Front Access USB hub
    • Multi-function remote w/ PC media playback control
    • Front panel PC Power switch control
    • On Screen Display Control via Touchscreen
    • NTSC / PAL Multi-System
    • 16x9 Aspect Ratio
    • High Resolution Display
    • Night time backlight dimmer for night-time use
    • High Performance Video and VGA Processor
    • High Quality Scaling & Anti-Aliasing
    • Automatic display adjustment
    • Anti Glare Coating
    • "E" Mark Certified for Automotive use
    Package content:
    • In-Dash Monitor
    • Remote Control
    • Instruction Manual
    • Connection cables
    • Touchscreen drivers for DOS, Windows, Windows VistaLinux, and Mac OS
  • XENARCKENWOOD
    Model #: MDT-X7000Kenwood KVT-716DVD
    For In-Car entertainment, In-Car Computing N/A Input for locked navigation unit
    TMD Automotive Grade LCD PanelN/A
    Fully motorized screen with Tilt adjustment7" Motorized LCD video screen with touchscreen controls
    Built-in 55w x 4 amplifier50 peak x 4 channels
    Built-in CD, video DVD playerDVD/CD player
    Built in DVD decoder with Dolby DigitalN/A
    USB DVD-ROM in PC modeN/A
    Built-in AM/FM Radio TunerBuilt-in AM/FM Radio Tuner
    5-wire resistive Touch Screen (USB)Non USB Touchscreen
    Multi-Monitor Touchscreen SupportN/A
    DVI Input x 1 / VGA Input x 1,  AV Input x 2AV Input x 2
    PC Audio input x 1, AV Output x 1N/A
    Built-in 2 port Front Access USB hubN/A
    Multi-function remote w/ PC media playback controlWireless Remote
    Front panel PC Power switch controlN/A
    On Screen Display Control via TouchscreenLocked system
    NTSC / PAL Multi-Systemdual-zone capability
    High Resolution DisplayN/A
    Night time backlight dimmer for night-time useN/A
    High Performance Video and VGA ProcessorN/A
    High Quality Scaling & Anti-AliasingN/A
    Automatic display adjustmentAutomatic display adjustment
    Anti Glare CoatingAnti Glare Coating
    Screen Size:  Diagonal 7"  (16:9)Screen Size:  Diagonal 7"  (16:9)
    Physical Resolution: 800 (H)  x 480 (V) WVGAN/A
    Supported Resolution:  640 x 480 ~ 1024x768N/A
    Dot Resolution: 2400 x 480 = 1,152,000 (dots)N/A
    LCD Brightness: 400 cd/m²LCD Brightness: 360 cd/m²
    Touch Screen Interface: USB portN/A
    Operating Voltage Range: DC 12V, 1A Operating Voltage Range: DC 12V, 1A
    18 Month Warranty90 Days Parts and Labor
Browse for more products in the same category as this item:
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > In-Dash Touchscreens
Monitors and Touchscreens > Xenarc
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs $259.95
Xenarc 702TSV VGA Touchscreen Monitor, 1000nit $459.95
Xenarc 700TSV 7" TFT LCD Touchscreen Monitor New 2010 Model $319.99
Xenarc 700IDT 7" In-Dash LCD Touch Screen Monitor $399.95
Xenarc 706TSA 7" TFT LCD Touchscreen Monitor w/ DVI & VGA & AV inputs $409.95
