Home > Monitors and Touchscreens >
  Xenarc 805TSV Touchscreen Monitor
Alternative Views:
Our Price: $319.00
Sale Price: $291.95
You save $27.05!
Stock Status:In Stock
Product Code: MON-056
Description Technical Specs Extended Information
XENARC 805TSV  TFT LCD Touchscreen Monitor w/ VGA; AV inputs
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 8" LCD screen with VGA input and Touchscreen while utilizing the latest LED Backlight technology.
This popular product incorporates the innovation of our VGA 8" model along with a 5-wire resistive Touch-Screen panel.  Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface.  You can connect several of our touchscreen monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
Why do our products outlast others at extreme environments?  Why do our products have wider temperature range and wider voltage input range? It is because our mission is to offer our customers the best.  By utilizing high grade components, this monitor is perfect for industrial, in-car computing applications or any other applications where a small, durable monitor is required.
This monitor comes included with an instruction manual, a monitor stand, a stylus, an AC adaptor, a connection cable, a cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Windows Vista, Linux, and Mac OS.
To install this monitor in a vehicle, check out our Windshield Mount, Model #WSM-1.  Please also take a look at the non-touch version 805YV if you don't need a touchscreen or the aluminum casing 800TSV if you require a more ruggedized enclosure.
Features
    • For In-Car Computing, PC, Server, GPS, POS, and various VGA Use
    • 5-wire resistive Touch Screen (USB)
    • Multi-Monitor Touchscreen Support
    • VGA Input (15 pin D-SUB) x 1 & Video Input x 2
    • Audio Input x 3 / Built-in Speaker
    • NTSC / PAL Multi-System
    • 4:3 Aspect Ratio
    • High Resolution Display
    • High Brightness LED Backlight *New*
    • Adjustable backlight level for night-time use
    • Realtek High Performance Image and Video Signal Processor
    • AISS - Advanced Image-Scaling and Shaping
    • Factory Mode to disable front buttons *New*
    • Factory Mode to disable On Screen Text *New*
    • Last Input memory
    • Last Power setting memory
    • IR Remote Control
    • Auto power-on upon signal detection
    • Automatic display adjustment
    • On Screen Display Control
    • Mirror Image Flip
    • Vertical Image Flip
    • Desktop Stand
    • VESA 75mm mounting holes
    • 26-Pin heavy-duty connector with connector locking
    • Anti Glare Coating
    • Supports 9V DC ~ 30V DC
    • "E" Mark Certified for Automotive use
    • Compare Features
Browse for more products in the same category as this item:
Monitors and Touchscreens > 8" Touchscreens
Monitors and Touchscreens > Xenarc
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs $259.95
Xenarc 702TSV VGA Touchscreen Monitor, 1000nit $459.95
Xenarc 700TSV 7" TFT LCD Touchscreen Monitor New 2010 Model $319.99
Xenarc 700IDT 7" In-Dash LCD Touch Screen Monitor $399.95
