Tired of turning page after page of map guides? Having trouble reading the small print off the map? Stuck on congested streets/freeways and can't find alternative routes? Can't focus on driving because you need to keep on referring back to the map for the next street turn?
iGuidance has the solution for you!
iGuidance is a vehicle navigation system that uses Global Positioning System (GPS) satellites to find your current position on a detailed map. iGuidance map is powered by Navteq Corporation, a world leader in premium-quality digital map data. Tap a few buttons to enter a destination, and iGuidance not only finds the best route (quickest or shortest), it also provides verbal turn-by-turn directions to get you to where you need to be.
iGuidance is perfect for any sales professional, delivery person, real estate agent, commercial driver, tourist, field inspector, or anyone else who needs to be on the road frequently. It does not require any activation or monthly fee. Most importantly, iGuidance software includes BOTH notebook and pocket PC versions, so you simply install the software to your laptop and/or pocket PC, connect it to your GPS receiver, and you are ready to go.
Map includes U.S., Canada, Hawaii, Alaska, Puerto Rico, & US Virgin Islands
Map size 1.3GB and is pre-generated (for users of Pocket PC version iGuidance, min. 2GB SD/Mini SD/Micro SD card is required to install the map file)
| Main program: | 3-5MB PPC (but need 23-25MB initially until after 1st launch); 15MB (laptop/UMPC/Car PC) | Map Data Size:
| 1.3 GB
Compatible Operating Systems:
| | | | PC version: Windows ME/NT/2000/XP/Vista (not compatible w/ Windows MCE edition) | | | PPC version: Windows Mobile 2003/2003SE, WM5.0, & WM6.0 | |
Pocket PC's/Pocket PC Phones:
| | | | Dell Axim (excl. X5)
| | | Garmin iQue*
| | | HP iPAQ
| | | iMate
| | | Mitek (A701)
| | | Palm Treo 700W/750/750WX
| | | Most PPC Phones incl. HP 65xx/69xx, Samsung i730/i760, PPC 6600/6700/6800****, ATT 8125/8525/8925*** etc)**
| | | *Note: compatible Garmin iQues include M3,
M4, M5
| | | **Note: not compatible w/ PPC/PPC phones w/o touch screen support
| | | *** Note: v4 has conflict w/ AT&T MediaNet GPRS/3G/Edge modem. Need
to temporarily turn GPRS connection off until iGuidance is fully
launched.
| | | **** Note: iGuidance is incompatible w/ the new ROM released by HTC
which enabled the internal gps chip. iGuidance will continue to work
with an external gps receiver while using PPC6800/Mogul, but in order
for iGuidance to work w/ the internal gps, user will need to
download/purchase Franson's GPSGate (express or standard version) via http://franson.com/gpsgate/
| Receivers:
iGuidance works with any GPS receivers that are based on the NMEA protocol using RS232, USB, CF, or bluetooth interface. USB-based receivers must come with an USB-to-Serial bridge driver that is Microsoft certified in order to work with iGuidance on your laptop. This driver is provided by the gps receiver manufacturer. *For Globalsat SDIO-502 receiver, please generate map to laptop/PC C:\ drive first (C:\iNav iGuidance) then copy file over to SD card. | Minimum System Requirements:
| | | | Laptop: DVD ROM drive, USB port, minimum 1GB RAM, PIII CPU or above
| | | PPC: minimum 30MB for program installation on PPC & minimum 20MB on-board main program memory for route calculation (customers w/ insufficient storage memory can choose to install program on a SD card
instead)
Features
NEW! Over 6 million POI destinations with subcategories
Multiple stopover/waypoints
Itinerary planning (user-defined trip order)
Detour by distance or avoid road
Shortcuts to "Home" (user-defined) & POI subcategories (program default)
Trip status box displaying ETA, distance, remaining time, and speed
simultaneously
Trip computer displaying start/end time, total distance traveled, average
& top speed
4 pre-defined map color themes
Single click POI navigation from onscreen icon (name/phone displayed if
available)
Real time weather report (internet access required via LAN, BT, mobile phone,
Wi-Fi, etc)
Turn-by-turn visual instructions with voice prompts
Search by city or street first, intersection, city center, POI, LAT/LON (PPC
only)**, Outlook contacts (PPC, U.S., & some Canadian addresses only), favorites, and recent
Maneuver guidance screen
Route list display
Quickest, shortest, local, major, ferry, toll, and carpool route options
Automatic day/night map color switching
Record and play route/track
Customizable hotkeys for quick command (for PDA)
Default (non-customizable) hot keys for quick command (for laptop)
Automatic & dynamic rerouting for wrong turns
Special safety features (speed and fog alert)
Easy to use keypad for name entry
Will map to LAT/LON location associated w/ an actual street # &
name in map data only. Otherwise, will map to closest LAT/LON
coordinates w/ associated street # & name.
Map-
NEW! Updated Navteq map now including Puerto Rico & US Virgin Islands
NEW! Pre-generated singel map file (1.3GB), which requires min. 2GB
SD/Mini SD/Micro SD/CF card when using iGuidance Pocket PC version
Detailed map display w/ street names in 2D & 3D view
Zoom in and out
Visual Display-
Large finger accessible menu buttons
UMPC/Car PC version bundled
Bordered roads
Railroads & major roads marking
Enhanced 3D display
240x240 square screen support
VGA & landscape view support
Full screen mode for laptop
Geo-features differentiating lands, body of water, airport, etc
Full screen mode for pocket pc and laptop
Large finger accessible buttons
Intuitive menu options
Distance indication bar
Automatic color modes for day and night display
Bright colors for visual enhancement
Voice- NEW! Text-to-Speech (street name included in voice guidance)
Turn-by-turn voice prompts
Side of street & fwy # notification
Automatic voice alerts before each turn/exit
Repeat voice direction feature
Multiple distance notification for each maneuver
