Home > Peripheral Devices > Fusion Brain >
  Fusion Brain Version 4.0
Alternative Views:
Our Price: $59.99
Notes: Hobbyist Grade
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: COM-089
Cables:
Accessories:
Description Extended Information
The Fusion Brain has 16 digital on/off outputs and 13 analogue sensor inputs. The free Fusion Control Centre software from the software section interacts with the board to create the possibility of animated outputs, and graphical input displays. Requires unregulated or regulated 12vDC supply - can be connected straight to car battery, or to regulated 12v source. Can withstand power fluctations from 9v to 15v on the input.
Sensors can be connected to any one of the 13 analogue inputs for readings varying from Temperature to Distance to the amount of Light present.
Relays or LEDs can be connected directly to any of the board's 12 digital outputs header pins allowing for easy installation. Additionally, all 16 outputs are PWM capable. With 500mA of output capacity, each output can drive LEDs or small motors at varying brightness/speeds with from the PWM. With the addition of a MOSFET driver such as the Fairchild FQP50N06, much larger motors can be driven. The FQP50N06, for example, can drive up to 50 amp loads.
Download The Manual
Improvements over Brain v3:
  • 16 Digital Outputs
  • 13 Analog Inputs
  • Selectable Power Source (USB or 12vDC Jack)
  • 30% smaller form factor (70mm X 45mm)
  • Better power filtering and protection
  • Ability to update firmware via USB
  • Ability to update firmware via ICSP header in event of bootloader corruption
  • Improved signal routing for analog inputs
  • Pulse Width Modulation, 256 steps with 42uS minimum pulse width (may need firmware update, provided free and uploadable over USB)
Please note:
Mp3Car will not provide tech support in regards to use and set-up of this product.  Customers are expected to use the HYPERLINK "http://www.mp3car.com/vbulletin" Mp3Car forums for assistance in these areas.
Related Products...
Ultrasonic Distance Sensor
Our Price: $34.99
Add
Thermometer
Our Price: $7.99
Add
Thermometer
50A Current Sensor
Our Price: $19.99
Add
50A Current Sensor
Volume Control (Linear Potentiometer)
Our Price: $9.99
Add
Infrared Distance Sensor
Our Price: $24.99
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Mp3Car Forum Made Products
Peripheral Devices
ATM 16 Gauge Fuse Holder w/Cover ATFH16MC-10 $0.99
Lilliput 629GL-70NP 7" VGA Touchscreen $239.99
30 Minutes of Consultation ($330 per hour, purchased in 30 minute increments) $165.00
Install Bay 80 Amp Manual Reset Red Button Breaker CB80MR $9.99
1/2 " Self Wrapping Split Braided Sleeving- Fire retardant - by the foot, techflex $0.99
6 FT M/M MD8 Mini-Din 8 pin Cable $5.95
FORD/LINCOLN/MERCURY 1982-85 - INTO CAR $0.99
FORD/LINCOLN/MERCURY 1986-UP - INTO CAR $0.99
Panasonic Slot Load CW-8124 DVD-ROM/CD-RW Combo Drive 24x24x24 Disc Drive $60.99
