Home > Computer Hardware > Motherboards > Intel >
  Intel BLKD945GCLF2 Mini-ITX Motherboard with Integrated Atom™ Processor
Alternative Views:
Our Price: $79.99 New Low Price
Stock Status: (Out of Stock)
Availability: Ships in 1 to 2 Business Days
Product Code: MTB-057-0001
Description Extended Information
Great new low power board prefect for 12/24 volt computing applications.
Featuring the integrated 45nm Intel® Atom™ Processor and the Intel® 945GC Express Chipset, this board is an energy-efficient solution for many applications. Designed with Intel's leading edge 45nm Hi-k metal gate processor, this board delivers incredible opportunities to communicate, listen, watch, play, and learn via Internet connectivity.
This product will ship in bulk packaging or be integrated with the product of your choosing. Intel retail boxes are available upon request with a large order. There will be a small price increase for Intel retail box requests.
  • Intel D945GCLF2 Mini-ITX
  • Very low power
  • Dual Intel Atom  1.6Ghz processor included
  • 2GB memory max
  • 3 year warranty from Intel
  • Up to 8 USB ports without Hub  4 back 4 headers
  • 10/100/1000 lan
  • Operating Temp 0c-55c
This retail boxed part number of this product is D945GCLF2
Please Note:  This motherboard will not work with the VoomPC-2 CarPC Enclosure.
Features
Processor Support
• Dual Core Intel® Atom™ Processor 330 integrated (1.6 GHz / 512 KB L2 Cache / 533 System Bus) Chipset
• Intel® 945GC Express Chipset with ICH7
I/O Features
• Integrated super I/O LPC bus controller
• Two SATA ports (3.0 Gb/s)
• One PCI local bus slot
USB 2.0
• Four back panel ports
• Two onboard header providing four additional port support
Audio Solution
•     Realtek* ALC662 audio codec (5.1 channel HD audio)
LAN
• Onboard 10/100/1000 Ethernet LAN
SPI - System BIOS
• 4 Mb Flash EEPROM with Intel® Tiano BIOS featuring Plug and Play, IDE drive auto-configure
• Advanced configuration and power interface V1.0b, DMI 2.0
• Intel® Rapid BIOS Boot Optimized POST for fast access to PC from power-on
System Memory
Memory Capacity
• One 240-pin DIMM connector
• Designed to support up to 2 GB of system memory using DDR2 667 / 533 SDRAM
Memory Type
• DDR2 667 / 533 SDRAM
Memory Voltage
• 1.8 V
Wake-up from Network
• Wired for Management (WfM) 2.0-compatible
• Support for system wake-up using an add-in network interface card with remote wake-up capability
Expansion Capabilities
• One PCI bus add-in card connector Jumpers and Front-Panel Connectors Jumpers
• Single configuration jumper design
• Jumper access for BIOS configuration mode Front Panel Connectors
• Reset, HD LED, Power LEDs, power on/off, aux LED
• Two USB 2.0 header
• Audio header
Mechanical
Board Style - Mini-ITX/microATX compatible 6.75” x 6.75” (17.145 cm x 17.145 cm)
Desktop Board Power Requirements ATX12V or SFX12V
Environment
Operating Temperature 0° C to +55° C
Storage Temperature -40° C to +70° C
Average Customer Review: Based on 1 Reviews. Write a review.
Related Products...
Intel BLKD945GCLF2D Mini-ITX Motherboard with Inte
Our Price: $84.99 New Low Price
Add
Intel BLKD945GCLF2D Mini-ITX Motherboard with Integrated Atom™ Processor
Intel BLKDG45FC
Our Price: $135.99
Add
D945GSEJT
Our Price: $119.99
Add
D945GSEJT
  1 of 1 people found the following review helpful:
Power Connector November 9, 2008
Reviewer: Dan Taylor from Elkridge, MD United States
This board has a BTX connector, and requires a P4 Connector.
You will need to get an adaptor to make this work:
http://www.logicsupply.com/products/atx_cable_24
http://www.logicsupply.com/products/pwr_2p
Was this review helpful to you?
Browse for more products in the same category as this item:
3-pin Female-Male Shielded Extension Wire $1.99
Intel BLKD945GCLF2D Mini-ITX Motherboard with Integrated Atom™ Processor $84.99 New Low Price
Micro Shutdown Controller $41.99
9pin Mini din extension cable $9.99
FORD/LINCOLN/MAZDA 1998 - INTO CAR/16 PIN $0.99
