Features
Processor Support
• Dual Core Intel® Atom™ Processor 330 integrated (1.6 GHz / 512 KB L2 Cache / 533 System Bus) Chipset
• Intel® 945GC Express Chipset with ICH7
I/O Features
• Integrated super I/O LPC bus controller
• Two SATA ports (3.0 Gb/s)
• One PCI local bus slot
USB 2.0
• Four back panel ports
• Two onboard header providing four additional port support
Audio Solution
• Realtek* ALC662 audio codec (5.1 channel HD audio) LAN
• Onboard 10/100/1000 Ethernet LAN
SPI - System BIOS
• 4 Mb Flash EEPROM with Intel® Tiano BIOS
featuring Plug and Play, IDE drive auto-configure
• Advanced configuration and power interface
V1.0b, DMI 2.0
• Intel® Rapid BIOS Boot Optimized POST for fast access to PC
from power-on
System Memory
Memory Capacity
• One 240-pin DIMM connector
• Designed to support up to 2 GB of system
memory using DDR2 667 / 533 SDRAM
Memory Type
• DDR2 667 / 533 SDRAM
Memory Voltage
• 1.8 V
Wake-up from Network
• Wired for Management (WfM) 2.0-compatible
• Support for system wake-up using an add-in
network interface card with remote wake-up
capability
Expansion Capabilities
• One PCI bus add-in card connector
Jumpers and Front-Panel Connectors
Jumpers
• Single configuration jumper design
• Jumper access for BIOS configuration mode
Front Panel Connectors
• Reset, HD LED, Power LEDs, power on/off, aux LED
• Two USB 2.0 header
• Audio header
Mechanical
Board Style - Mini-ITX/microATX compatible 6.75” x 6.75” (17.145 cm x 17.145 cm)
Desktop Board Power Requirements ATX12V or SFX12V
Environment
Operating Temperature 0° C to +55° C
Storage Temperature -40° C to +70° C
