Home > Computer Hardware > Motherboards > Intel >
  Intel D945GCLF Mini-ITX Motherboard with Integrated Atom™ Processor (BLKD945GCLF)
Alternative Views:
Our Price: $59.99 New Low Price
Stock Status: (Out of Stock)
Availability: Ships in 1 to 2 Business Days
Product Code: MTB-057
Description Extended Information
Great new low power board prefect for 12/24 volt computing applications.
Featuring the integrated 45nm Intel® Atom™ Processor and the Intel® 945GC Express Chipset, this board is an energy-efficient solution for many applications. Designed with Intel's leading edge 45nm Hi-k metal gate processor, this board delivers incredible opportunities to communicate, listen, watch, play, and learn via Internet connectivity.
This product will ship in bulk packaging or be integrated with the product of your choosing. Intel retail boxes are available upon request with a large order. There will be a small price increase for Intel retail box requests.
  • Intel D945GCLF Mini-ITX
  • Very low power
  • Intel 1.6Ghz process included
  • 2GB memory max
  • 3 year warranty from Intel
  • Up to 6 USB ports without Hub  4 back 2 header
  • 10/100 lan
  • Operating Temp 0c-55c
This retail boxed part number of this product is BOXD945GCLF
Features
Processor Support
• Intel D945GCLF Mini-ITX Motherboard with Integrated Atom™ Processor (BLKD945GCLF)
• Intel® 945GC Express Chipset with ICH7
I/O Features
• Integrated super I/O LPC bus controller
• Ultra ATA 100/66 device support
• Two SATA ports (3.0 Gb/s)
• One PCI local bus slot
USB 2.0
• Four back panel ports
• One onboard header providing two ports support
Audio Solution
• Integrated High Definition Audio (2+2 channel)
with front panel header
10/100 Network Connection
• Onboard 10/100 Ethernet LAN
SPI - System BIOS
• 4 Mb Flash EEPROM with Intel® Tiano BIOS featuring Plug and Play, IDE drive auto-configure
• Advanced configuration and power interface V1.0b, DMI 2.0
• Intel® Rapid BIOS Boot Optimized POST for fast access to PC from power-on
System Memory
Memory Capacity
• One 240-pin DIMM connector
• Designed to support up to 2 GB of system memory using DDR2 667 / 533 SDRAM
Memory Type
• DDR2 667 / 533 SDRAM
Memory Voltage
• 1.8 V
Wake-up from Network
• Wired for Management (WfM) 2.0-compatible
• Support for system wake-up using an add-in network interface card with remote wake-up capability
Expansion Capabilities
• One PCI bus add-in card connector Jumpers and Front-Panel Connectors Jumpers
• Single configuration jumper design
• Jumper access for BIOS configuration mode Front Panel Connectors
• Reset, HD LED, Power LEDs, power on/off, aux LED
• One USB 2.0 header
• Audio header
Mechanical
Board Style - Mini-ITX/microATX compatible 6.75” x 6.75” (17.145 cm x 17.145 cm)
Desktop Board Power Requirements ATX12V or SFX12V
Environment
Operating Temperature 0° C to +55° C
Storage Temperature -40° C to +70° C
Related Products...
Intel BLKDG45FC
Our Price: $135.99
Add
D945GSEJT
Our Price: $119.99
Add
D945GSEJT
Intel BLKD945GCLF2D Mini-ITX Motherboard with Inte
Our Price: $84.99 New Low Price
Add
Intel BLKD945GCLF2D Mini-ITX Motherboard with Integrated Atom™ Processor
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Immersion TouchSense PR-1000 Programmable Force Feedback (Haptic) Rotary Encoder with USB Interface $119.99
USB-UIRT (Universal Infrared Receiver/Transmitter) $49.95
Mitch JS USB Audio Selector 4 inputs 1 output - MJS-UAS4S $60.00
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
