Home > Computer Hardware > Cables and Adapters > Cable Kits >
  uSDC Cable Kit
  uSDC Cable Kit
Our Price: $9.99
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: CBL-005
Description
The uSDC Cable Kit has everything needed to connect a uSDC20D into an automotive application (except heavy gauge wire). The Faston Crimp Connectors can be crimped or soldered to 18-12 gauge wire that is used for connecting the automotive system to the main power lugs (VIN, GND, VOUT), and the accessory lug (ACC). The 24-inch Motherboard cable connects from the uSDC20D to the power switch of your motherboard. The shunt jumpers select optional features. The Optional Feature Cable is good for connecting the Computer On Sense feature, or the Aux connection for your application.
uSDC Cable Kit Contents:
2 - 0.1 inch Shunt Jumpers
4 - 0.25 inch Faston Crimp Connectors
1 - 24-inch, 2-pin Motherboard Power Switch Cable, 0.1" connectors on both ends
1 - 10-inch, 2-pin Optional Feature Cable, 0.1" connector on one end
Related Products...
CarNetix CNX-XSC3 Cable Kit for the Xenarc MP-SC3 Power
Our Price: $14.95
Add
3/16" HEAT SHRINK 3M POLYOLEFIN-50% SHRINK TUBING
Per Foot $0.85
Add
3/16
Aopen Power Pac
Our Price: $24.95
Add
Aopen Power Cable Kit
CarNetix CNX-XSC8 Cable Kit for the Xenarc MP-SC8 Power
Our Price: $14.95
Add
Cable Ties 8-1/2" Black 100 Pcs.
Our Price: $4.99
Add
Cable Ties 8-1/2
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Micro Shutdown Controller $41.99
9pin Mini din extension cable $9.99
FORD/LINCOLN/MAZDA 1998 - INTO CAR/16 PIN $0.99
